I don't know if my English dictionary is working or if it has some issues with very basic words. For example, I had to make the following AutoText rules, most of which I thought were ridiculous:
ay -> at
biy -> bit
bur -> but
di -> do
ie -> is
fir -> for
noe -> now
hoe -> how (seriously, who would type the word "hoe" more often than "how"?)
It would actually be nice to create my own list of words to never use, or label as "low priority" like the ones I listed above.
Questionable English Dictionary
c00ller
- Phone: HTC Hero CDMA
c00ller
Re: Questionable English Dictionary
Hmm, so I am the only one having these issues?
There are 2 different things:
- Valid words must not be "auto-texted" by default; if you never use them feel free to define this auto-text yourself (for instance "fir" or "hoe").
- Indeed invalid words are in the dictionary, they should be removed
For "biy", there is an ambiguity between "buy" and "bit", so I'm not sure what the auto-text should be
c00ller
Thanks for confirming! Just FYI here's another word that bothered me the other day: nit. Although I see the ambiguity between "nut" and "not".cyril wrote: - Indeed invalid words are in the dictionary, they should be removed
Edit: here's another, "evem"
hotaru
- Phone: htc hero cdma / cm 6 (android 2.2.1)
Re: Re: Questionable English Dictionary
there's also the fact that "nit" is a word...c00ller wrote:Just FYI here's another word that bothered me the other day: nit. Although I see the ambiguity between "nut" and "not".
anyone may use and modify any smart keyboard skins that i post on this site.
you may distribute those skins or modified versions of them for free.
you may not sell any of my skins or any derivative works of my skins.
