Hello there.
I really like your application, it eases my pain while writing something on a touch screen =)
Could you also please add a Turkish keyboard layout? I have found a page that shows the layout and unicode codes.
http://ascii-table.com/keyboard.php/179
Thanks for all your efforts,
kandemirb
Turkish layout
Re: Turkish layout
do you think it is useful to add the extra keys (it will make the keys smaller) ?
It's also possible to add the characters in the popup after a long press (on "s" key for instance), as already done for the accents in other languages
Re: Turkish layout
For me it wouldn't be a problem without the extra keys, but I don't know what other people would prefer because the keyboard layout is pretty much standardized and the extras (small ı, capital İ, Ğ, Ş, Ç, Ö and Ü) are seperate, not accented letters . Is that too much trouble to make both versions?=)
P.S. In addition to the extra letters, in Turkish the small letter of the capital letter "I" is "ı" (dotless i) and the capital letter of the small letter"i" is "İ" (capital dotted I)
Edit: I've also came across to a Turkish T9 dictionary for Windows Mobile, I'm not sure if it's any help though.
http://forum.xda-developers.com/showthr ... 093&page=3
Re: Turkish layout
Hi, I'm sure you are very busy but are you considering adding the Turkish layout?
Re: Turkish layout
You can use the bug tracker (http://bugs.smartkeyboardpro.com) so that I don't forget to do it
Re: Turkish layout
This will be in the next version (but this "İ i I ı" thing was a nightmare :p )
