Expandable Bottom Row
cfitzgerald11
- Phone: HTC EVO
The one feature is I think this keyboard is missing is the option that thumb keyboard as added. Smart Keyboard pro is all about being able to customize and personalize your keyboard to your liking with tons of features you can toggle in the keyboard's settings. A great option would be adding the ability to change the way the bottom row of the keyboard, including the spacebar, period, comma, ect. scales. You would essentially be able to make that whole row bigger or smaller according to a slider in the settings much like there is for the time pressed for secondary keys to be displayed. For end users this adds a option that is extremely useful. In my case, it would be a bigger space bar since in almost every single one of my texts I make the mistake of hitting b or v in instead of space. Thanks for the consideration
