Hello there,
I must say I really enjoy this keyboard and that's why I find this very annoying.
I use IM+ for chatting and I get this annoying bug...I can't see what I type...the cursor just disappears along with the word im typing and I only see it when I press space...
Thx
Problem while typing in IM+
fdujmov
- Phone: Htc desire 2.2
Re: Problem while typing in IM+
Is it something which happened after an update? In that case, just restart your phone, it's probably because IM+ was running when you did the update, and Android doesn't handle that correctly.
Otherwise, when did the problem start? I just tried IM+ and have no problem at all
fdujmov
Sry it took me some time to answer but I just wanted to wait and see if it happens, and it did...but unfortunately I can't find any pattern to why it happened...the cursor just disappears with the letters and I only see words in prediction bar....
