Hi i have 3 phones 2 HTC Desires running 2.2 and just purchased a HTC Wildfire to set up for my mum.
Both Desires are using the latest version of Smart keyboard Pro along with the Wildfire which is running 2.1 update 1
but i cannot install or download skins for the Wildfire they will not appear in Android Market at all. I use the great range
of skins that Punyweakling makes he rocks. The skins say they are for version 1.5 or 1.6 and above.
Can anyone help skins work fine with the Desire phones all 3 have the Pro version i know because i paid for it.
It has got me stumped as some of the other apps on the Market thru my PC say they are for versions 1.6 and above
but do not even come up when searchin with Wildfire thru Android Market???????
Please help if you can
Smart Keyboard Pro Skins
smithy47
- Phone: HTC Wildfire version 2.1 update 1
Re: Smart Keyboard Pro Skins
Which skins are you talking about? If some developer published a skin app on the market and forgot to make it compatible with some phones, you should contact him directly.
smithy47
Thanks Cyril i contacted the developers at Punyweakling who makes the best skins for your Awesome Smart Keyboard Pro
and they said it was a resolution issue which they were going to work on to resolve.
Thankyou for your input and keep up the brilliant work.
smithy47
Forgot to put in some smilies.
