Can I edit the dictionaries?
London
Phone: SE X10 Mini, And. 2.1
Post by London »
Hi!
Is it possible to edit the dictionaries? I think the Danish one has some oddities I would like to delete. I can't find any obvious file...
And thank you Cyril for the best Android keyboard!
Re: Can I edit the dictionaries?
You can't, but you are welcome to contribute to a better danish dictionary ;)
London
Post by London »
I would like that! How do I get started?
All what is needed is a word list sorted by decreasing frequency of usage. The current list has only 27k words, which is quite small.
London
Post by London »
Can I get a copy of that list? Then I will begin by correcting wrongs.
And is there some "normal" way people make these -- i.e. get the words and frequencies?
fvs114
Post by fvs114 »
Maybe you should try this,this, this or this to get corpus or list of words. 8-)
London
Post by London »
Those are definitely in another league, containing 22000k words... I'll have a look once I've gotten started.
I would like to add to the current list first, but also remove from it -- it currently contains a lot of annoying entries as many words are suggested both capitalized and not.
Can you supply the current one, Cyril?
Here is the current list. However I'm not sure how you can merge it with another one, as the resulting list still has to be sorted by frequency...
danish.zip
(123.37 KiB) Downloaded 451 times
London
Post by London »
Hey Cyril,
I have now obtained some word lists (thanks fvs114, in the end I contacted someone from one of the places, was redirected, and now I have a good, sorted list!)
How large can the dictionary be?
fvs114
Post by fvs114 »
Slovenian dictionary contains 259k words.. Cyril would cut it from bottom (low frequent words) but it wasn't necessary.
___________________________________
FVS114
SGS GT-I9000 - Gingerbread 2.3.4
