Using the Market app, I can't find Smart Keyboard Pro. I am using an HTC Tattoo (screen may be a limitation?)
I could install using slideme.org but now I also can't install the French keyboard...
Any help? Maybe you should put in your app that it is compatible with small resolution screen also (cause it's working in english)
Cannot find French for Smart Keyboard
Re: Cannot find French for Smart Keyboard
I don't understand why... Anyway you can also download dictionaries here: http://android.cdeguet.net/files/
