Since version 4.1.1 or 4.1.0 (i updated from 4.0.2 to 4.1.1), when i long press space bar key, the selected symbol is "*" instead of "0". As "0" is the alternate symbol of space bar, it should be the selected symbol in case of long-press i suppose. When performing a long-press for all other keys, the alternate symbol is selected.
This issue occurs with T9 english or french layouts. I did not check other layouts.
I am certain that this issue did not exist with 4.0.2 and previous versions of Smart Keyboard Pro.
Long-press space bar keydoes not select the alternate symbol
gaegouli
Re: Long-press space bar keydoes not select the alternate sy
Which phone (and screen resolution) do you have?
gaegouli
My phone is a HTC Desire
According to HTC website, the screen resolution is 480 X 800 WVGA
When i long-press the space key, i have a list containing from left to right : 0, _, @, *
* is selected (it is the one which is the most above the spake key, but i am not sure if there is a link with the current matter)
