Any idea for that?
It used to work pretty beautifully, but I now have no suggestion at all...
Thanks again !
I'm French... but French suggestions don't work anymore
cornwall
- Phone: Google Nexus One (SFR)
Re: I'm French... but French suggestions don't work anymore
Have you installed the french dictionary (it's now in a separate app) ?
cornwall
Hi, Cyril.
Can't find it on the market... WIll try again, otherwise, I'll get back to you !
Thanks for the reply,
A bientôt !
A bientôt !
cornwall
Nevermind !
Found it
Regards
Found it
Regards
faquin
- Phone: HTC Tattoo 1.6
Hi cornwall,
I'm also looking for the french keyboard, where did you find it?
cornwall
Hi !
To access it, you shoudln't follow the "downlolad dic" from the Application, but directly go to the market and type in "french dictionary" or "smart keyboard". Scrolling the page should lead you to the holy grail.
Regards
Regards
