in not I'm...
prisma7000
in not I'm...
Post by prisma7000 »
Hey again and this is the last thing I have a slight problem with. On my htc's touch keypad, it somehow works out what the most appropriate word which should appear next would be. i.e. if I write a sentence like the following: "I'm going to spend the day in the pool", it automatically writes "in" in the correct place. This one uses "I'm" as default in every situation. Is there any way of fixing this? J
Re: in not I'm...
"im" should not be corrected to "in" but to "I'm". Do you have the smart dictionary on, and if yes, can you check without it?
