Just purchased & I really like Smart Keyboard.
I would like to request one small change. The word popups are Android Orange. How about an option to make them Eris Green?
Green & Gesture to dict
JKib
- Phone: Eris 1.5
JKib
- Phone: Eris 1.5
Re: Green instead of Orange
LOL, you really got me. I saw the update & thought, "Wow, that was fast."
Dang it.
Oh well. But is the green instead of orange even a consideration?
Dang it.
JKib
- Phone: Eris 1.5
Re: Green & Gesture to dict
Something else I just noticed that would be great:
If Gesture options could be added to open the User Dict. & the Custom Text lists.
Well, do you mean you want the suggested word in green instead of orange ?
For the swipe actions, that's something possible, I'll thank about it for a next release
JKib
- Phone: Eris 1.5
[quote="cyril"]Well, do you mean you want the suggested word in green instead of orange ?/quote]
Yes. I know it seems trivial, but the orange just doesn't match the Eris color scheme.
JKib
- Phone: Eris 1.5
Come on...please add the green option so I can make this my primary keyboard. I keep hoping at every update!
You mean you really don't use it because the text is orange ?
Yes I can add this option
JKib
- Phone: Eris 1.5
Oh... I've been using it. But I'm also still searching for the perfect keyboard. You add the green, & my search is over.
The layout is great. The "force prediction" is slow on the internet, but cool. The custom dictionary is awesome (even better when/if you add gesture access).
The OCD in me just needs the green (like the caps lock indicator on the shift key).
Thanks for your time.
Ok so watch the advanced settings in the next release
- Capture d’écran 2010-03-31 à 23.42.30.png (55.16 KiB) Viewed 12167 times
JKib
- Phone: Eris 1.5
Excellent. Seriously! Thanks.
Off to post review.
Off to post review.
