My smart keyboard pro does not pop each letter when i touch it on the keyboard. Is there a setting to enable this?
Paul D.
Pop up letters
Re: Pop up letters
And what about "Show preview popup: Display a popup when a key is pressed" ?
Re: Pop up letters
Dear Cyril
I did not understand your reply. Is there a setting to make letter pop up when you touch them?
Thanks,
Paul DeLeeuw
Thanks,
Paul DeLeeuw
Re: Pop up letters
Yes this setting is called "Show preview popup" (in "General Settings"), and it's enabled by default, so you should have it unless you changed something yourself.
Re: Pop up letters
How do I get to these "settings"? They are not in the general Android Settings>Applications> Smart Keyboard folder. When you enable Smart Keyboard and press Menu, settings is not an option.
Thanks,
Paul D.
Thanks,
Paul D.
Re: Pop up letters
There are 2 ways:
1) Android Settings > Language & keyboard > Smart Keyboard Pro
2) Long press on 123 key in the keyboard
Re: Pop up letters
Thanks, sorry for the ignorant question. One other thing. Due to some problem with Google, I cannot download any paid apps anymore. Free apps work fine. Is there some way to download your updates some other way, maybe through my home computer.
Truly sorry for the bother.
Paul D.
Paul D.
richardkemp
- Phone: ZTE Blade - CM7
