Honeycomb skin
kromonos
Phone: Samsung Galaxy GT-I5500
Re: Honeycomb skin
Post by kromonos »
Honeycomb Xoom LDPI on Samsung Galaxy GT-I5500 240x320 SKP 4.2.3
Re: Honeycomb skin
Right, a mistake on the pressed button picture... :?
This one is working on my Nexus One.
LDPI.zip
(33.92 KiB) Downloaded 469 times
schrochem
Re: Honeycomb skin
Post by schrochem »
love the skins.
I really like the color scheme you did on the kromoneycomb
http://www.dexilog.com/smartkeyboard/fo ... 7&start=70
Anyway you could throw those colors into the cupertino skin?
http://www.dexilog.com/smartkeyboard/fo ... f=13&t=617
I always liked those smaller keys..... :)
Re: Honeycomb skin
schrochem wrote:love the skins.
I really like the color scheme you did on the kromoneycomb [...]
Anyway you could throw those colors into the cupertino skin?[...]
Meaning the exact cupertino skin, with just the kromoneycomb colours instead of original ones ?
that's to say, dark blue/grey keys, and a gradient when pressed ?
schrochem
Re: Honeycomb skin
Post by schrochem »
Yes the color of the keys that are also in your honeycomb skin. The only thing from the kromoneycomb is the blue color in the pressed.png
I have and hdpi phone btw.
I tried doing this myself in photoshop with not so great of luck... :)
I do have a 'different' looking keyboard now! but the colors aren't as cool as your honeycomb.
Re: Honeycomb skin
Feel free to get the file from my skin, I would have made it for you with pleasure, but I'm cruely lacking free time these days :( ...
Re: Honeycomb skin
New update available (see 1st post for details)
dan55
Re: Honeycomb skin
Post by dan55 »
hi
thanks for the new skin.
downloaded it and renamed it as have a few honeycomb ones but can't tell which it is :-\
is there any way to tell?
thanks
dan
Re: Honeycomb skin
dan55 wrote:hi
thanks
dan
you can edit the skin.xml file, inside the .zip, and add something to the name of the skin to identify them in the list
dan55
Re: Honeycomb skin
Post by dan55 »
ok cool thanks
