That's nice, thanksdan55 wrote:sent you some beer money dude
Honeycomb skin
- meyergre
Re: Honeycomb skin
Like it ? buy me a beer
Re: Honeycomb skin
When you gonna add the suggestion bar?
- meyergre
Re: Honeycomb skin
probably in a few days i'm just finishing a super mario skin, and another hello kitty one, and then i'll add this bar on all my old skins
EDIT : Having some troubles with my new skins, I'm leaving them in standby for now. Honeycomb now has its prediction bar skinned
Re: Honeycomb skin
meyergre wrote:probably in a few days i'm just finishing a super mario skin, and another hello kitty one, and then i'll add this bar on all my old skins
You da man!
Re: Honeycomb skin
This should go well with all those Honeycomb themes (rooted phones). I'll have to see.
Re: Honeycomb skin
With Honeycomb (XOOM).zip my SGS is not perfect. Could you please repair it? You can see the problem on my screencapture.meyergre wrote:Honeycomb theme for Smart Keyboard Pro
NEWEST - 06/13/2011 (updated) + New pictures : now looking exactly like the XOOM's one
+ prediction bar ! (skp 4.2+)
05/08/2011 + pictures are now reduced and should be adapted to all screens (ldpi, mdpi, hdpi)
+ now just named "Honeycomb"
+ added on MegaUpload (downloading from MU makes me earning reward points on it, so it's a free way to support me )
+ smooth edges
04/29/2011 + enlargement of the light on the CAPS LOCK
+ correction of the colors to get closer to the original ones (both light and dark buttons )
+ adding a search symbol (it was the same than "return" one before)
Thank you!
- Problem with shift&delete button!
- SC20110621-131653.png (59.39 KiB) Viewed 7323 times
- meyergre
Re: Honeycomb skin
sure, not a big deal. i'll do it as soon as i get some time probably in a few days...
Re: Honeycomb skin
I wanna kno what otha colors skins are u comin' up with?!?
- meyergre
Re: Honeycomb skin
I'm not dead !
I'll release the corrections for this Honeycomb skin, plus all the different versions - ldpi - mdpi - hdpi - before the end of the day.
- meyergre
Re: Honeycomb skin
should fit all screens.
- Honeycomb (XOOM) HD.zip
- (19.33 KiB) Downloaded 479 times
- Honeycomb (XOOM) LDPI.zip
- (51 KiB) Downloaded 403 times
- Honeycomb (XOOM).zip
- (32.12 KiB) Downloaded 438 times
