hello !
Really like the latest update mate.
Just did a small touch' to get alt-label keys a bit "lighter" because it was too darky for me and sometimes can't see them when I'am out (sun condition).
Here is what it looks :
Honeycomb skin
Re: Honeycomb skin
- landscape.png (34.81 KiB) Viewed 9802 times
- Honeycomb (AndroidGX).zip
- (9.38 KiB) Downloaded 3983 times
- meyergre
Re: Honeycomb skin
You're right, it's better like you did. more visible. Maybe it depends on the screen's technology too nicely done
Like it ? buy me a beer
- Phone: Samsung Galaxy GT-I5500
- Contact:
Re: Honeycomb skin
Re: Honeycomb skin
hmm strange, I just opened the original zip file from meyergre and modified the xml inside to change the color and saved it normally it should work without any problem then, did you tried to select another skin and back to mine after ? or a reboot / dalvik cache cleaning maybe ?
- meyergre
Re: Honeycomb skin
My original zip is mostly for Standard or High resolution devices ; his wildfire S has a smaller res., so some adaptations are needed on the key's PNGs. (basically, deleting some transparent pixels between the button and the 9-patch black line)AndroidGX wrote:hmm strange, I just opened the original zip file from meyergre and modified the xml inside to change the color and saved it normally it should work without any problem then, did you tried to select another skin and back to mine after ? or a reboot / dalvik cache cleaning maybe ?
Btw, I reduced the symbols too, they might be a bit pixelated...
Try this one, and come back to me if it's not betterkromonos wrote:Could you please make the gap between the keys smaler?
- meyergre
Re: Honeycomb skin
I guess it's OK now ?
or maybe you would prefer 1 more pixel less on each side ?
- meyergre
Re: Honeycomb skin
Done
- Contact:
Re: Honeycomb skin
Perfect work Big thx I love it
I'll post screenshots this afternoon, when I'm at home
