Honeycomb skin
Honeycomb skin
Honeycomb theme for Smart Keyboard Pro
EDIT :Give a look at AndroidGX improvements on this skin here ;)
NEWEST - 08/07/2011 (updated)
Honeycomb.zip
(9.37 KiB) Downloaded 88556 times
+ pictures are more clean
+ prediction bar update
+ buttons update
! Basically designed for landscape use, if the graphics are bigger than the buttons, just ask for a smaller version.
06/13/2011
Honeycomb (XOOM).zip
(10.84 KiB) Downloaded 19694 times
+ New pictures : now looking exactly like the XOOM's one
+ prediction bar ! (skp 4.2+)
05/08/2011
Honeycomb.zip
(28.98 KiB) Downloaded 22109 times
+ pictures are now reduced and should be adapted to all screens (ldpi, mdpi, hdpi)
+ now just named "Honeycomb"
+ added on ImageMegaUpload (downloading from MU makes me earning reward points on it, so it's a free way to support me ;))
+ smooth edges
jeckert21
Phone: HTC EVO 4G Version 2.2
Re: Honeycomb skin
Post by jeckert21 »
Great work! I would be very interested. Thanks.
Re: Honeycomb skin
Thanks, jeckert21.
Here is a new version, looking closer to the original skin. (see 1st post) ;)
jeckert21
Re: Honeycomb skin
Post by jeckert21 »
LOVE it! Thanks for the update. I really appreciate it.
Re: Honeycomb skin
you're welcome ;)
Don't hesitate to ask for update if there is something wrong
dan55
Re: Honeycomb skin
Post by dan55 »
nice job :) i really like the bright blue key press colour - makes i pop nicely
thanks
dan
wretchedlocket
Re: Honeycomb skin
Post by wretchedlocket »
Any chance of getting a non-bold font version? I'm on the nook color with HDPI and bold keys are a little overkill. Aside from that, its awesome. Great work.
Sent from my Nook Color (zoom2) using Tapatalk
Re: Honeycomb skin
Sure. Should I remove the white "shadow" around the letters too ? (I've never had a Nook, so I don't really see what you mean :oops: )
wretchedlocket
Re: Re: Honeycomb skin
meyergre wrote:Sure. Should I remove the white "shadow" around the letters too ? (I've never had a Nook, so I don't really see what you mean :oops: )
Actually, I got bored and removed the bold myself. I hope you don't mind. I've never messed with keyboard skins (been meaning to though) so I thought this was a good opportunity to see what these themes consist of. Removing the bold was just enough. The shadows actually look good.
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Re: Honeycomb skin
Don't hesitate to extract the files to modify them, I'm not gonna bite ;)
