Who can create a skin please
Matthew
Phone: HTC Wildfire 2.2.1
Post by Matthew »
Hello, i wanted to create my own skin i failed, so, somebody can create a skin for me ?
Bye.
Re: Who can create a skin please
Do you want some help with your skin? I swear, once you understand how to do it, it's easy.
Matthew
Post by Matthew »
Oh yes please :D
Can you tell me what you did, and provide the file?
yakie996
Phone: htc widfire 2.3.4
Post by yakie996 »
maybe you can help mee??
yakie996 wrote:maybe you can help mee??
Sure. What are you stuck on?
yakie996
Post by yakie996 »
i have make this just for try... but draw9patch won't open...
skins.zip
(24.05 KiB) Downloaded 587 times
yakie996 wrote:i have make this just for try... but draw9patch won't open...
Draw9patch won't open? What does it do?
I've found that you don't even need draw9patch to create the .9.png's. Just open them up in Photoshop or whatever program you use, and make sure that the black pixels on the border are all black, or #000000. If even one is, say, #010101, it won't work.
yakie996
Post by yakie996 »
yess!! I tryet open draw9patch open ant works :D
yakie996 wrote:yess!! I tryet open draw9patch open ant works :D
That's good =)
