Full screen & Landscape mode not working right
tmiv44
Phone: HTC Thunderbolt
Post by tmiv44 »
When in Landscape mode The keyboard knows when to go into full screen and when not to. However, when you are using the native email app (not gmail) it uses full-screen mode for the to: and Subject: lines, but not for the body of the message. the the bar that gives you the options "send, save as draft, discard" are displayed between the keyboard and the text box. this means you can't see but one line of text. the native keyboard doesn't do this, it knows to hide the "send, save as draft, discard" bar. this isn't an issue in gmail, or the text message app. Here's an example:
The "send, Save as draft, discard" shouldn't be there. Also, i have my keyboard height set pretty small so i can see 1 line of text, the default height hides the text box all together.
I'm using a HTC Thunderbolt.
-Tm
DJjay
Phone: HTC Incredible S
Re: Full screen & Landscape mode not working right
Post by DJjay »
BUMP!
Please fix - I have this exact same issue...HTC Incredible S
Indeed the HTC mail client doesn't go in fullscreen mode even though the option "no landscape fullscreen" is off. It's under investigation.
Note that it happens with all keyboards except Touch Input, so either it's a bug in HTC mail client, or a secret "feature" from HTC to make their mail client work only with their keyboard...
tmiv44
Post by tmiv44 »
stupid HTC software >:-(
anyone got recommendations on a free alternative email client?
-Tm
kromonos
Phone: Samsung Galaxy GT-I5500
Post by kromonos »
schrochem
Post by schrochem »
Indeed this is a very annoying issue. I've been told android doesn't do push mail like blackberry, but I have the HTC mail client set up to get work mail via web exchange. It comes to my phone before I see it on my work pc via outlook. I tried k9 but it didn't get the push and had to pull. So I uninstalled it and still looking for an alternative just because of this landscape issue. Any ideas? I might even pay the $10 for that exchange client so I can type in landscape :-)
Actually a workaround is to NOT go to fullscreen mode, then it's better. Just enable the option "no landscape fullscreen".
OK, I found where this problem comes from, once again it was due to changes done by HTC in the Android framework...
I fixed implementation of fullscreen in the latest beta, and now the fullscreen in landscape works correctly in HTC Mail client.
jcdinma
Phone: Samsung Epic4G SPH-D700 gingerbread.EI22
Post by jcdinma »
I have the same issue on my samsung epic on gingerbread.
I tried the HTC solution you made in the beta but when I go to type in the box, nothing shows in the box under landscape mode.
If I go back to the email the text is there but formatting is not easy.
Currently I have to shrink down the keys and it looks like the picture at the beginning of this thread.
This issue only happens in the native android email client. Text messaging is great.
Prior to gingerbread it was fine.
