Here it is, as promised: Don't know if it works or not. I'm the developer of several ROMs for my phone and since I flash it so much, haven't had time to download Smart Keyboard. I'm missing it thoughdan55 wrote: awesome thanks.
cool. that's a tasty bit of kit for sure
have a good new years
glowkey (colors: blue, red, green, honeycomb!)
Re: glowkey (colors: blue, red, green, honeycomb!)
cool thanks. will get that loaded asap
I can't live without it on mine. its one of the first apps to sort out after a flash
thanks
dan
thanks
dan
cool - thanks - works a treat - cheers
btw: what is going on with this forum and all those dodgy threads! :/
cheers
dan
cheers
dan
For anyone who could be interested, since I liked very much the style of this skin but I also loved the minimal black one, I made this dark gray one that to me fits really perfectly
Hope the author it's ok with this (in an open source conception )
and btw, anyone knows how to modify the suggestion bar?
- Glowkey DarkGray preview
- glowkey_darkgrey.JPG (91.36 KiB) Viewed 8298 times
- glowkey_darkgrey(also HDPI).zip
- Glowkey Skin in elegant darkGray
- (31.18 KiB) Downloaded 696 times
One year since the original release, to the exact date and time- and over 100,000 total downloads. Thanks guys
- Phone: bionic 2.3
I love the glowkey blue and glowkey blue white. Is there anyway you can add a suggestion bar that matches the theme instead of the stock light grey one? editing the Smiley hotkey menu to fit the theme would be cool too! Thanks!
archangel008 wrote:I love the glowkey blue and glowkey blue white. Is there anyway you can add a suggestion bar that matches the theme instead of the stock light grey one? editing the Smiley hotkey menu to fit the theme would be cool too! Thanks!
Glad you like it. I plan on implementing the suggestion bar when I can, but unfortunately, that is not one of my top priorities right now.
- Phone: bionic 2.3
Okay thanks. I look forward to seeing it. Keep up the good work.
Ordered a Galaxy Player 4.0 from Best Buy yesterday during their Memorial Day sale (got it $40 off), so I can finally have an HDPI device to test on. It will come by the end of next week, and then I am out of town the week directly after, so I will try and implement the suggestion bar in three weeks.
issue with red skin
I really like this red skin because it matches my overall phone theme. but two Major things that needs to be resolved.
1. the suggestion bar is white, which breaks the overall dark theme. so it must be black
2. the ALL CAPS button and T9 buttons don't change when they are turned on or off.
I would really appreciate a fix
