glowkey (colors: blue, red, green, honeycomb!)
Ok, here it is! Longly anticipated! There's something here for everyone. There's four colors initially, and each has two versions: one with colored keys, and one with normal white keys. Download what you want, but MAKE SURE YOU DOWNLOAD INTO sdcard/skins! ENJOY!
Two updates are on the way... the first will update all the skins with the new prediction bar, and the second will be two additional skin colors.
Thanks to:
jeckert21, for awesome beta testing!
mylenthes, for providing the # value used in glowkey_honeycomb!
Go tell them both thanks!
Here's glowkey_blue:
glowkey_blue.zip
(42.49 KiB) Downloaded 237173 times
And with white text:
glowkey_blue_white-text.zip
(37.47 KiB) Downloaded 96783 times
Re: glowkey [colors: blue, red, green!]
glowkey_green:
glowkey_green.zip
(42.22 KiB) Downloaded 66167 times
With white text:
glowkey_green_white-text.zip
(37.16 KiB) Downloaded 38215 times
glowkey_red:
glowkey_red.zip
(42.17 KiB) Downloaded 42014 times
With white text:
glowkey_red_white-text.zip
(37.15 KiB) Downloaded 31174 times
'glowkey_grey' and 'glowkey_grey_white-text' are in beta right now, but they'll be posted here once they're finished.
glowkey_honeycomb:
glowkey_honeycomb.zip
(42.1 KiB) Downloaded 27478 times
glowkey_honeycomb_white-text:
glowkey_honeycomb_white-text.zip
(37.07 KiB) Downloaded 21934 times
glowkey_purple will go here when I fix it. Apparently, it doesn't work.
I'll add additional skins here.
mylenthes
Phone: g2 with honeybread
Post by mylenthes »
Woot
The blue doesn't match honeycomb very much but its close enough and still very great. I hope in the future you will add a honeycomb blue one.
Just my $0.02
mylenthes wrote:Woot
How is it?
mylenthes
Post by mylenthes »
I edited my message before you asked that as I didn't want to double post.
