Whenever I change options in SKP, I have to get out, open Gmail (or something else), and start to enter a message/email to be able to play around with the keyboard now that my changes are made. Then I have to go back into the settings, change something else, and repeat.
It would be great if there was a "hot key" command while in settings that popped up a dummy notepad application with the keyboard open allowing you to play around with the keyboard with the settings you must made. Then once finished, some "hot key" or keystroke takes you back to the settings.
And if the idea of a hot key doesn't seem ideal, what about a gesture specific to setup for launching the dummy notepad?
I realize this may seem complicated, but trust me, if implemented properly this will be a huge improvement!
Thanks,
Doug
Way to "preview" keyboard with options selected
OldDogEyes
- Phone: HTC Evo/2.2 + Rooted Nook Color/2.1
