Voice input
Voice input
I just started using your free trial. I noticed when I use voice input that only the first part of my dictation comes out for review and not the whole dictation. I was wondering if this can be changed so I can review the entire dictation before I send it. Perhaps that is a function only available to me if I bought the paid version, which I intend to do anyway. Thank you.
Re: Voice input
Well, voice input uses Google speech recognition service, so if it doesn't work well you have to complain to Google, not to me
Re: Voice input
Hello Cyril,
what the keyboard could try to do better so is setting the language hint. A few versions (maybe 4.0) ago it correctly hinted the keyboard language to google voice recognition. Then it broke completely letting google do automatic language detection, wihch does not work at all. Now (v4.2.0) it works with english only and ignores the kwyboard language.
Re: Voice input
voice input works well in Motorola-Froyo but not in Galaxy Tab- Ginger bread. I think there are some trouble to recognize changed language.
Voice Input should follow the language selected-shifted- but it didn't. just stays and suggests such one language which set by system.
plz, solve this trouble.
Re: Voice input
Maybe something is not done correctly, but the language hint is set, otherwise it would never have worked. If someone broke something, it's Google, not medebugfix wrote:Hello Cyril,
frannieland
- Phone: 817 847 9226
Re: Voice input
I am having a different issue with voice input. In portrait mode, when mic button is pushed it only goves ES as language option. The landscape mode allows both ES and EN. Is there a way to have only EN as an option?
Re: Voice input
What do you mean by "gives ES as language option"? Voice input button is not supposed to give any language option, it's just supposed to show the voice input window.
frannieland
Re: Voice input
My son found the answer straight away.... I had somehow clicked on two different languages in language selection area. I was looking for the answer in the voice input section.
