Wont change skin/layout
Matea
- Phone: Xperia X10 with [ROM] kX10 R2B
Hey hey been using SDK for awhile and now after a re-install it just wont change any skin or key layout for me eventho it does change skins in the list when i look through them, but when i leave setup and check any app or anything where you use the keyboard its still the gray boring default one and im not even sure its the SDK default for all i know it can be android or systems.... ive re-booted/turned of/taken out the battery and SIM ect but nada..
Re: Wont change skin/layout
Have you changed the input method? (long press in a text box, choose "Input Method")
Matea
Cheers all sorted;)
well spent money btw for all you who cant decide if you should get full version;) keep up the awesome work m8
