My problem is that the language bar on the bottom is not big enough to hold all of these languages. It works if I select the one on the end and then tap the language button, but it would be more convenient if the bar would either automatically scroll as you slide your finger across or go to two rows high.
If this is something that you are able to implement that would be great, but I also realize that many do not use such a vast number of languages on a daily basis.
Again thank you for creating such a great product. I can't remember what life was like before SKP. It seems to be a keyboard that was designed specifically for multilingual typing.
