I dont know how many people wants this, but i would love to have some new symbols on the keyboard, actually i only need 1, which i use a lot (passwords) and since this keyboard doesnt have it, i need to change keyboard to another keyboard to type it and then back, its kinda annoying if i have to do this every time, the symbol im talking about is -> ł (lower case) and Ł (upper case), i think it wouldnt harm noone and maybe you can make a few people happy if you can add this one on the L key.
Can it be done please? (=
Special Symbols
Re: Special Symbols
What about using the option "Force latin layout" and set it to Polish layout?
NubCake
Re: Special Symbols
Well, i just tried that and it worked, but by doing this i lose other characters (not symbols), for example Š (which is on S key) and probably others too (C -> Č, Z -> Ž), so it kinda doesnt work, so its still faster for me to just use another keyboard to type this, because if i wanna type Ł i have to go to settings and check Force Latin Poland and then go back again and choose Nothing or Slovenian.cyril wrote:What about using the option "Force latin layout" and set it to Polish layout?
Re: Special Symbols
Ok, so I can add "ł" to the english international layout, which also has these other letters
NubCake
Re: Special Symbols
If you can't add it to Slovenian or every language, that would be cool too, any solution is better then nothingcyril wrote:Ok, so I can add "ł" to the english international layout, which also has these other letters
