Hi i submitted a new bug in the bug tracker: http://www.dexilog.com/smartkeyboard/bu ... php?id=229
Can you correct this bug in the next release? For me it's a real annoying bug since i always use this excellent keyboard...Thank you for your support
PS after you downloaded the backup.zip can you delete it? Thank you
Bug in the autotext crashes the keyboard
Re: Bug in the autotext crashes the keyboard
indeed there was a problem due to the apostrophe in the autotext. It's fixed in the latest beta
thank you cyril!
Re: Re: Bug in the autotext crashes the keyboard
what's new in this beta? (currently using it)cyril wrote:Hello
