By the way,
The active state for shift symbol still needs fixing: :)
Code: Select all
<symbol><shift-locked>filename.png</shift-locked></symbol>
Any chance to fix it for the upcoming 3.7 release? Would be great if it loads that symbol, preferably on both states: shift toggled and shift locked.
Thanks Cyril.
Cyril, my "Skins" folder is in my phone SDcard. The internal one (aka not the one with Avatar movie).
onthecouch wrote:Cyril, my "Skins" folder is in my phone SDcard. The internal one (aka not the one with Avatar movie).
Ok, but I'm not sure I understand ;) On the Nexus one, there is only one SD card, and it's a microSD (inside the phone, of course), and it's accessible in "/sdcard" directory. When I say the skin is now copied automatically to the internal storage, I really mean internal ;) (i.e not the removable SD card, but the internal flash memory)
zen wrote:The active state for shift symbol still needs fixing: :)
Code: Select all
Thanks Cyril.
Too late for 3.7.0 obviously ;) But promised I will work on this
And thanks again for the Galaxy skin, it's a bomb!
markdmac
Phone: Samsung Fascinate Android 2.1
Post by markdmac »
I have created my own skin by modifying the sample skin. When I click on a key the preview has a white background. How can I change that color to match the color of the alternate character popup? Thanks.
Droid for MDPI and higher
With so many of you using the Galaxy, I think it's time to also give a little love for its distant-cousin from Motorola. :D
So here's a new addition to the Smart Keyboard family: Droid.
Download here:
droid.zip
Droid, by Zen
(31.51 KiB) Downloaded 1600 times
Both normal and high resolution displays are supported.
Droid landscape view
markdmac wrote:I have created my own skin by modifying the sample skin. When I click on a key the preview has a white background. How can I change that color to match the color of the alternate character popup? Thanks.
If you meant the preview popup box showing which letter/symbol were selected, unfortunately, you can't modify its background at this moment.
Here is another with a little more dimension.
Moved here: http://www.dexilog.com/smartkeyboard/fo ... f=13&t=623
eolsgaard
Phone: HTC Droid Indredible
Post by eolsgaard »
zen wrote:
I've updated the Galaxy with the new bold fonts tag, and also tweaked the Enter/return key symbol to look more like the original Galaxy S.
For some reason the bold feature doesn't seem to be working on my Incredible... looks the same as normal.
Oveja
Phone: Google Nexus One, Android 2.2
Post by Oveja »
Make sure you download the one that zen posted, because the one that's now integrated in 3.7 doesn't have bold fonts (Fix plz cyril? c: ). And make sure you are selecting the correct Galaxy skin in the keyboard settings (there will be two labelled "Galaxy", choose the second).
