hi
I noticed similar. I've always wondered if more gaps would help
cheers
dan
Honeycomb skin
- meyergre
Re: Honeycomb skin
here it is, with a more important gap.
If it's not enough, tell me your phone's resolution. This one is optimized for low-resolution screens, that's why the distance is this much little between the keys.
But anyway : notice that the picture of the key is only a background, the keys themselves doesn't have any real gap between each other.
- Kromoneycomb.zip
- (28.68 KiB) Downloaded 740 times
Like it ? buy me a beer
Re: Honeycomb skin
Hey thanks meyergre,
I was thinking of a more significant gap but I see that's a major rework.
I started reading the 'create your own skins' thread and put in a request for the iphone.zip that came with skp.
I'd like to give making a skin a whirl....
I was thinking (but not so sure since I've never done it) that I could take the png files from the iphone skin and recolor them.
Anyway, it seems like an easy starter project....
I have a thunderbolt with 480X800 I believe.
Thanks again.
Thanks again.
- meyergre
Re: Honeycomb skin
Well, it's not a big deal in fact. Once the PNG is drawn, i just need to add some transparent pixels on each side to increase the gap
Sent from my Nexus One using Tapatalk
Re: Honeycomb skin
Hey meyergre,
After looking at your visual tutorial I'm getting a better idea of how the key size is made.
I decided to get out a trusty ruler and just measure the keys right on the phone....
I compared the iphone skin to your latest kromoneycomb skin.
Looking at portrait mode they look vastly different but measure almost the same.
On my phone the iphone was 5X8mm with a 1mm gap between keys. your skin was 5X9mm with a 1mm gap.
I'm guessing the visual difference is a limitation of my ruler...perhaps the iphone is more like a 1.5mm gap.
However, in landscape it's easily seen. Iphone measured 7X7mm with a 2mm gap, your 9x9mm with a 1mm gap
I realize the actual letter and hit point are in the same spot but I think the smaller keys and bigger gaps make me get closer to that hit point.
- meyergre
Re: Honeycomb skin
With more gap
- skin+gap.zip
- (9.56 KiB) Downloaded 701 times
Re: Honeycomb skin
himeyergre wrote:here it is, with a more important gap.
oh right. so visual gap means nothing to key press accuracy ?
space key is the real issue here I find. especially in landscape
cheers
dan
- meyergre
Re: Honeycomb skin
I may be wrong, but as I understood, it's just a picture displayed as a background of a transparent button. In fact, the gap is only a transparent part of the image, but it's still a part of it, you see what I mean?
Maybe your device is lacking accuracy around the borders, I'm having this kind of trouble with my Notion Ink Adam tablet, it's very hard to catch the notification bar for example...
In portrait mode, you can add some space under the keyboard, I don't think it's possible in landscape... maybe you can try a calibration in the keyboard options ? or even increasing the key's height ?
Re: Honeycomb skin
hi
yes I've tried calibration a few times but not noticed improvement.
correct. you can't add space under the space in landscape. although I have suggested it
cheers
dan
cheers
dan
Re: Honeycomb skin
sent you some beer money dude
