Finally got this to work! YES!
So basically I ended up giving ASTRO file manager a go, downloading the .zip skin file directly from the phone (you have to enable an attachment preference in ASTRO settings to ensure it downloads files sucessfully), then moving it into the mnt/sdcard/skins folder. Then it magically appeared in the settings in Smart Keyboard Pro.
Glad I got it sorted.
How to install skins
Jackie
- Phone: android incredible
Re: How to install skins
I did everything the instructions said and still nothing happened . Still don't have the keyboard I downloaded
- Phone: Samsung Moment, Acclaim, and Galaxy S
Put the zip file of whatever skin you downloaded into /sdcard/skins. If the skins folder is not there, create it my using a file manager or a terminal emulator:Jackie wrote:I did everything the instructions said and still nothing happened . Still don't have the keyboard I downloaded
Code: Select all
$ cd /sdcard
$ mkdir skins
newcube
FYI - to see the skins on a Galaxy Note you need to create a new folder called skins in the /sdcard folder which IS NOT the actual SD card in the phone! The external card sits at /sdcard/external_sd so putting the skins folder there does not work.
superleeds27
- Phone: I9100 4.0.4
Any reason why im seeing this?
For the record its the HTC Sense 4.0 Skin 1.1
- Screenshot_2012-06-29-13-06-17.png (37.68 KiB) Viewed 11415 times
NoPodi
- Phone: HTC Desire
+1 - have no idea why this is suddenly happening.superleeds27 wrote:Any reason why im seeing this?
i tried *sdcard* and *emmc*. it doesn't matter ... pls help!
NoPodi
- Phone: HTC Desire
ok i got the solution. if you are on a rooted custom ics at least.NoPodi wrote:+1 - have no idea why this is suddenly happening.superleeds27 wrote:Any reason why im seeing this?
This should solve the problem:
https://play.google.com/store/apps/deta ... aW5kZXIiXQ..
chrissul
I just joined today been reading the create skins directory onto my sd card is that the phones memory or external sd card.tried both and cant get it to work using samsung galaxy w
