3DKey skin
Re: 3DKey skin
Pino
Re: 3DKey skin
Post by Pino »
yhwhsupports wrote:Hey Pino, thanks for being one of those awesome people that helps make Android the best platform on a smartphone...
Hi! Thank you so much for your nice nice words, I never thought I was one of those though.. Also, the original 3Dkey is not my work, it's made by "Link", I just modified some details. As for the green keypress, I'll look into it this weekend. Stay well!
Re: 3DKey skin
Yes, Link made a totally bomb keyboard skin, but you've come along and done some refinement and did things for other people that they requested. I asked Link to do the green keypress before, but there was no answer. It's nice to have others out there that'll help others out when they get nothing out of it. Thanks again. You rock!
And P.S. I think I may like your black background even better than the gray now. ;)
Pino
Re: 3DKey skin
Post by Pino »
jeckert21 wrote:Pino, could your also make a 3Dkey3 version with the black background as well?
:idea:
3DKey3b.zip
(75.12 KiB) Downloaded 1166 times
Pino
Re: 3DKey skin
Post by Pino »
yhwhsupports wrote:Any chance you could make another with the keypress being the same color as the capslock indicator?
I've used the green colour you sent me, it seems it's the same green as the indicator
3DKey3d.zip
black background:
(82.38 KiB) Downloaded 1226 times
3DKey3c.zip
grey (original) background:
(82.39 KiB) Downloaded 1106 times
Re: 3DKey skin
You are too awesome! Thank you so much!!!
yakie996
Phone: htc widfire 2.3.4
Re: 3DKey skin
Post by yakie996 »
super!!! got you more of this :p
yakie996
Re: 3DKey skin
Post by yakie996 »
Pino wrote:Black background & suggestion bar
Image Image
maybe stubit question but whats the app you used for you battery persetage??
Pino
Re: 3DKey skin
Post by Pino »
maybe stupid question but what's the app you use for your battery percentage??
it's Battery Monitor (from SIMMO Publications)
Re: 3DKey skin
I can't say thank you enough, Pino. This skin is ten times better with the green keypress (and thats saying a lot, since 3DKey (and 3DKey2) is so amazing in itself. I'm practically drooling all over my phone while typing with my new green keypress with black suggestion bar, black background, and green highlight words. Don't know what else to say, but thank you, and I hope you receive the same service from others. You rock!
