c00ller
Phone: HTC Hero CDMA
Post by c00ller »
Thanks for the <highlight> option. :D The next time you update a beta, could you change the name? The only way I knew I had a different beta was to MD5 sum it.
Anyway, I found the source of error for my <recommend> color problems. A while ago, before the candidate bar and text was even themeable, I went to Advanced settings > Candidate color and changed it. Now, no matter what skin I choose, this option overrides the <recommend> color... how can I stop this?
I haven't gotten a chance to test any fonts. I like the default font anyway ;)
working fine ;)
using "Orbitron" font from Google.
Nice feature, thanks :D
c00ller wrote:Anyway, I found the source of error for my <recommend> color problems. A while ago, before the candidate bar and text was even themeable, I went to Advanced settings > Candidate color and changed it. Now, no matter what skin I choose, this option overrides the <recommend> color... how can I stop this?
Indeed, at the moment there is no simple way to stop using this option, except reinstalling the app or editing preferences.xml manually...
NoPodi
Phone: HTC Desire
Post by NoPodi »
Hi folks,
i'm desperately trying to build and install my skin.
how to install one i downloaded is simple. - to archive and install one by myself ... not.
i've no idea what i'm doing wrong.
what i'm doing:
i download the sample "android-plus"
-> pushing it to "skins"-folder
-> "Android+" shows up in the list
-> open the archive on my mac
-> archive it again (not important where i'm doing it or with which tool)
-> "Android+" doesn't show up in the list
do you have any idea what i'm doing wrong here??
cheers nopodi
Be careful to package it as ZIP file (not RAR, TAR, GZIP, or specific Mac format), without any password, encryption, or whatever. If it's still not good, try using the zip command-line tool in a terminal... I guess Mac OS's terminal is close to linux's one.
NoPodi
Phone: HTC Desire
Post by NoPodi »
meyergre wrote:Be careful to package it as ZIP file (not RAR, TAR, GZIP, or specific Mac format), without any password, encryption, or whatever. If it's still not good, try using the zip command-line tool in a terminal... I guess Mac OS's terminal is close to linux's one.
it's a zip archive every time. set on "normal" no password. even the rights on the files in the zip are the same.
i even tried it with the "Compress (Encrypt)" Option in MIUIs build in "ES File Explorer" …
Take care to zip your drawable folder and your skin.xml directly on the root of the archive, and not in a folder
NoPodi
Phone: HTC Desire
Post by NoPodi »
meyergre wrote:Take care to zip your drawable folder and your skin.xml directly on the root of the archive, and not in a folder
as is said. both zip files look exactly the same. even in win-rar on a pc. - i have no idea what happens during this process ...
this problem never occured before?
NoPodi
Phone: HTC Desire
Post by NoPodi »
ok :( - i'm sorry for talking crap! (in my first post ...)
now everything is working just fine and i'm excited creating my first skin ... i think i'll go after the windows phone 7 request.
cheers nopodi
Hey, if you found what was wrong, post the solution, so other people facing the same issue would find it ;) (and I'm cusious too :))
