Last question: Do you know anything about spacing? Like, each lines indent? I noticed yours has 2 spaces more with each line. Is that standard?
Haloruler64
- Phone: Samsung Galaxy S, Android 2.3.4
Thanks so much man
- meyergre
meaning the gap between the keys ? there is no "standard" actually, i found a balance which seems pleasant to me, that's all
i've drawn themes with thinner gap, and others even without buttons
so just do as it looks good to you
note : think about low-res devices : if the gap is too big, the buttons will be too much thin, and the result could be ugly.
by the way, Cyril, is there a way to include ldpi pictures in the zip, like we can already do for hdpi with the drawable-hdpi folder ? i know the android sdk support it, but it seemed not to work in smart keyboard last time i gave a try.
Like it ? buy me a beer
Haloruler64
No, I mean the gaps, or indents, before lines in the XML. You have to spaces more for each line down. That the standard? Or can you just press tab?
- meyergre
oh, sorry. it's a easier to read with tabulations, like in every markup, scripting or programming language,but you're not forced to follow it. any software would read it, with or without them.
Haloruler64
Thanks a lot man!
You know, it'd be interesting to create a skin optimized for 3D displays... once more phones then just the EVO 3D/Optimus 3D have them.
Can these skins be built on your computer and loaded into the emulator via the desktop?? Everytime I try to load to the emulator it is telling me no projects are found. I would really appreciate any help..
You have to create an sdcard for the emulator via command prompt, then manually push the skins to it. I can't remember exactly what you have to type, but when I get back in town I can find out unless someone else answers before meflagirl wrote:Hello
Okay thank you. I am going to try to get this figured out..
Hi there,
is it correct that there is no way to change the background color of a selected word in the suggestion bar?
It seems to be always orange, but it would be really cool to modify it.
