So it's normal it doesn't work, as the images you used for the prediction bar (at least the background image is not a valid 9-patch image, it doesn't even have a 1-pixel border)
Haloruler64
Phone: Samsung Galaxy S, Android 2.3.4
Post by Haloruler64 »
Right, they're .9 :/ why don't colors work in that field instead of a filename? I tried putting in a hex color but it didn't work either.
I didn't try actually, but colors instead of an image should work exactly like for the keyboard background (it's exactly the same code handling both)
i confirm. i updated my honeycomb skin with a gradient for the prediction bar, it works like a charm :-)
Haloruler64
I tried colors, it didn't work. Could you take a look at the skin.xml? See what I did wrong? It'd be SO appreciated!
Got it... your picture is not a 9patch (.9.png), it's a simple PNG file with 1x1px size.
If you want to use a colour, try this way :
Code: Select all
<color-top>#FF1b1b1b</color-top>
<color-bottom>#FF1b1b1b</color-bottom>
instead of your picture. It should solve your problem. ;)
Calling your file .9.png is not enough. Have a look at this page for more explanations ;)
Haloruler64
I know, the .9 was a stupid mistake :/ thanks though!
I tried to fix the xml, but it still doesn't work. Attached.
3DKeyP.zip
(53.1 KiB) Downloaded 549 times
Haloruler64 wrote:I know, the .9 was a stupid mistake :/ thanks though!
Here it is, working ;)
3D.zip
(64.47 KiB) Downloaded 731 times
I wrote the modification I told you in the XML, compressed once more, sent to my tablet, and... ta-daaaa! :)
Well, it's 11:22 PM on my side, so I'll go to sleep now :geek: have fun!
Haloruler64
Thank you SO much! It's highly appreciated! :D
What did I do wrong in my xml? I can't tell.
i'm not an expert, but i guess the <color> tag you used is not supported. in the xml i gave back to you, i'm using a gradient -as you did in your background- with the same color for the top and the bottom. you can use a .9.png picture too, but don't forget the expand marks on it ;)
