Kirara Young
Phone: Samsung Behold 2--> SGH-T939
Re: Create your own skins!
Post by Kirara Young »
Link wrote:Another version a little more glossy and removed the shift light.
I like this one, can you do a pink one? C :<3
schrochem
Post by schrochem »
I'd be up for giving this a try. anyway the iphone.zip could be posted? I'd like to build off of it (different colors,etc)
Easy start.
For those who are interested in : I just uploaded an illustrated step-by-step "How To" guide to create a SKP theme HERE :ugeek: (see 'Tutorial' tab).
It does not (at all!) replace the Cyril's indications from the 1st post, but I think it's a good complement, especially for beginners.
enjoy ;)
schrochem
Post by schrochem »
excellent meyergre.
I'm a visual learner so this really helps.
I downloaded the android sdk which asked me to download the java sdk and it just bogged down my pc (work one too.....)
So I had to uninstall so I could get some work down.... 8-)
Is draw9patch possible to have standalone?
If not, can designating where to expand be done in photoshop?
I messed with just changing some colors and it didn't come out right at all......
yes, you can draw expandable zones in photoshop. it's just some black pixels on each extremity. it's easier with the draw9patch, 'cause you can see the different areas, but it can be done with photoshop too. just take care to use a pure black with 100% opacity. ;)
For information it will be possible in version 4.2.0 to also skin the prediction bar (see this topic). Skin makers can already use this feature and let me know if it works (the extra tags will be ignored by older versions of the keyboard).
schrochem
Post by schrochem »
is the iphone.zip file proprietary or similar?
Haloruler64
Phone: Samsung Galaxy S, Android 2.3.4
Post by Haloruler64 »
I'm trying to edit an existing theme, 3DKey, and I cannot get it to work after adding in the part to get the prediction bar to change. Every time I edit the xml, the skin becomes all black. Can anyone help?
Can you post your new skin? If it becomes black it means you made a mistake with images, or you found a bug ;)
Haloruler64
Here it is.
It also did the same thing when I changed the file names to colors, the same colors of the background.
3DKeyP.zip
(64.66 KiB) Downloaded 698 times
