3DKey skin
Re: 3DKey skin
does this work for mdpi?
thomasva61
- Phone: droid x
Re: 3DKey skin
I really liked the skin "laptop2" that was posted a while back by you. Any chance of it being available again? Thanks much!
Re: 3DKey skin
GORGEOUS~! ^^ Thx Thx.. so muck ^^
Re: 3DKey skin
Black background & suggestion bar
- 3DKey2.zip
- (56.74 KiB) Downloaded 1814 times
- Phone: Droid X 2.2
Re: 3DKey skin
Awesome job on the black background with black suggestion bar, but is there any chance we can see this black suggestion bar on the original 3DKey, and perhaps with a green keypress?
Re: 3DKey skin
(made by request from jeckert21)
- 3DKeyBlue2.zip
- (54.54 KiB) Downloaded 1510 times
Re: 3DKey skin
yhwhsupports wrote:Awesome job on the black background with black suggestion bar, but is there any chance we can see this black suggestion bar on the original 3DKey, and perhaps with a green keypress?
- 3DKey3.zip
- (75.12 KiB) Downloaded 1421 times
Re: 3DKey skin
OUTSTANDING Pino! Thanks so much for doing that.
Re: 3DKey skin
Pino, could your also make a 3Dkey3 version with the black background as well?
Re: 3DKey skin
Hey Pino, thanks for being one of those awesome people that helps make Android the best platform on a smartphone. Thank you for making the green keypress. I've been using your 3DKey2 since I posted that request and I've come to liking the black background as well (though, I do prefer the gray background in landscape, but I don't use landscape on my phone). Any chance you could make another with the keypress being the same color as the capslock indicator? I don't know how much work it is to do so, but if you get some time and are willing, that'd be awesome. Otherwise I'll continue using this new 3DKey3, thanks a bunch (and the new green keypress would be fine on either the black background or the original). Thanks again, Pino...you rock!
