Sent from my GT-I5500 using Tapatalk
Honeycomb skin
kromonos
- Phone: Samsung Galaxy GT-I5500
- Contact:
Re: Honeycomb skin
Nice, but don't realy fits. I'll create a screenshot as soon as possible
- meyergre
Re: Honeycomb skin
Yes, please.kromonos wrote:Nice, but don't realy fits. I'll create a screenshot as soon as possible![]()
So I'll see what's wrong
Like it ? buy me a beer
kromonos
- Contact:
- meyergre
Re: Honeycomb skin
@kromonos :
Please try this one, and tell me if it looks better EDIT : attachment changed
kromonos
- Contact:
- meyergre
Re: Honeycomb skin
Looks already a bit betterkromonos wrote:I've updated the screenshots
I'll try to enhance the corners, looking a bit ... tooooo much pixelated
EDIT : just uploaded the new one, should fit perfectly now. (see last post, link updated)
kromonos
- Contact:
Re: Honeycomb skin
Oh yes. Looks very nice. Thanks for your work
EDIT: JJust updated screenshots
schrochem
Re: Honeycomb skin
Best skin I've had so far. The blue on strike helps me a lot. One thing I seem to have a problem with no matter the skin is hitting the space bar. I seem to hit b and v a lot. I wonder if having the space bar a different color on strike would help?
- meyergre
Re: Re: Honeycomb skin
try to calibrate the keyboard in the settings, to increase the key's height, or maybe to add some space on the bottom of the keyboard if you are in portrait mode, it should help. (i had the same issues before changing these settings;) )schrochem wrote:Best skin I've had so far. The blue on strike helps me a lot. One thing I seem to have a problem with no matter the skin is hitting the space bar. I seem to hit b and v a lot. I wonder if having the space bar a different color on strike would help?
i guess it's not possible to change only the spacebar's color, as it's designed as a normal key...
churro
- Phone: HTC Inspire
Re: Honeycomb skin
Where can I get that skin a few posts up?
