henhena
Phone: SVSBH
Post by henhena »
What is the best android on the market for t-mobile currently? Hey I've been thinking of upgrading to an android phone in the near future. I do like having a physical keyboard but if typing on a touch screen works well enough i wouldn't mind using that instead. I've noticed that the nexus one's specs but I'm not sure I want to spend 500 dollars on a phone unless its a big improvement over the others. What would you recommend?
_____________________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
Shorte85
Phone: Droid Incredible
Post by Shorte85 »
Okay, I was able to get the Draw 9-patch to open up, but I am certainly lost as this is my first time using it. What I am curious about is, do I create the button or key in a normal program such as photoshop or some other image editing software and then upload it in the draw 9-patch program or how exactly do you edit and make your own type of buttons? I'm definitely interested in learning this.
If I understand the first post, draw 9-patch program is supposed to just add the extra pixels needed or whatever such as the transparent and black pixels.
Any tutorials on this would be highly appreciated, maybe something a little more in depth to editing or creating an actual button. I definitely would love to know. Thanks!
Shorte85
Post by Shorte85 »
Does anyone know of a video or something that shows how to go about making a button? I would highly appreciate any information on this because I am pretty confused.
How exactly do I extract the sample skin into Eclipse?
I'm sorry. I haven't done this before :(
TheTehk17 wrote:How exactly do I extract the sample skin into Eclipse?
You don't need Eclipse, it's just a zip file with a xml and some images...
nicky041192
Phone: HTC Wildfire Official 2.2
Post by nicky041192 »
Any news on an online repo for skins?
Hi all,
I'm encountering a small issue... When I click one of my keys, the text color is white, instead of black as I wrote in the XML file... Maybe I missed a node :( ?? has anyone the same problem ?
Shorte85
Post by Shorte85 »
I think there should be a video made for those who don't quite understand how to make their own or design their own keyboards. I think it would help, and get the keyboard more known.
mrcymstr
Phone: Samsung Fascinate 2.2 stock
Post by mrcymstr »
I'm having a bit of an issue if someone would assist. I'm trying to make some themed skins in relation to say video games, movies, pop culture ect. So I created a simple skin, installed, but it didn't show in the list, then I tried something even simpler by simply modifying the sample with differentcolors for the symbols such as the space symbol. That also did not work, the sample itself works fine and I checked and double checked to make sure I had all my file names and such correct. Does anyone have any ideas? Like I said I just pulled up the symbols with gimp and changed the white to green. Thanks in advance! You guys are awesome!
Re: Re: Create your own skins
mrcymstr wrote:I'm having a bit of an issue if someone would assist. I'm trying to make some themed skins in relation to say video games, movies, pop culture ect. So I created a simple skin, installed, but it didn't show in the list, then I tried something even simpler by simply modifying the sample with differentcolors for the symbols such as the space symbol. That also did not work, the sample itself works fine and I checked and double checked to make sure I had all my file names and such correct. Does anyone have any ideas? Like I said I just pulled up the symbols with gimp and changed the white to green. Thanks in advance! You guys are awesome!
post your file if you want someone to tell you what's wrong ;)
