MeDo159
Phone: HTC Hero
Post by MeDo159 »
robbiep wrote:
cyril wrote:A black skin means there was an error while reading the skin. Which .zip have you installed? Is it with the latest version of SKP?
I am also getting just a black skin for both the GlossBlack and the 3DKey skins. The Droid skin works just fine however, so I'm pretty sure I'm copying everything over correctly.
EDIT: if it matters, I'm using a rooted cdma hero with cm6 nightly #99 (froyo)
YES!!!
this happens with these two skins exactly (GlossBlack and the 3DKey skins)!
I created those and tested them on the EVO. Anyone else having issues? I'll take a look and post new versions later today.
-Link
Link: that's right, your skin doesn't work on MDPI phones, I get this error:
Code: Select all
W/System.err(  296): com.dexilog.openskin.NinePatchUtilities$NinePatchException: invalid pixel found at x=4,y=0: D7000000
W/System.err(  296): 	at com.dexilog.openskin.NinePatchUtilities.decodeNinePatchDrawable(NinePatchUtilities.java:75)
W/System.err(  296): 	at com.dexilog.openskin.OpenSkin.loadDrawable(OpenSkin.java:319)
One of your images in drawable directory is invalid
By the way, I will create a "skins" section in the forum, it will be easier
OK, I understand... it seems you scaled your hdpi images to build the mdpi images, but this doesn't work ;) you need to create the 1-pixel border properly
And I just moved this topic to the new "Open Skins" forum. From new please create one topic for each skin, as this topic starts to become a mess ;)
That's what I figured and will post new ones shortly.
Sorry for the issues and delay. I have updated the original posts with new ZIP files.
You can find them here:
GlossBlack: http://www.dexilog.com/smartkeyboard/fo ... 2614#p2614
3DKey: http://www.dexilog.com/smartkeyboard/fo ... 2749#p2749
-Link
robbiep
Phone: cdma hero, cm6 nightly #99
Post by robbiep »
Link wrote:That's what I figured and will post new ones shortly.
-Link
Well, the 3DKey skin now works, and looks great by the way. Unfortunately, I'm still getting a plain black skin for the GlossBlack. Using a cdma hero, so mdpi.
Thanks again, though, for revisiting these and helping make them work on more phones. I, for one, really appreciate it. I'm really liking the 3DKey right now.
robbiep,
Thanks for the compliments and sorry for the trouble. I have modified them again. Try again and thanks for testing. ;)
robbiep
Post by robbiep »
Link wrote:robbiep,
Anytime. I love clean and simple themes. And I have plenty of time to test stuff out on the weekends.
Anyway, still no luck though on this newest GlossBlack.
robbiep wrote:
Link wrote:robbiep,
Ok, I have checked and double checked, resaved everything and made a new ZIP file. Please try again and if this doesn't work I would appreciate it if someone could take a look at my files and help me find what is wrong.
mikeyboi83
Phone: htc evo android 2.2
Post by mikeyboi83 »
i was wondering if anyone could possibly have the time to help me make my open skin something simple and easy hopefully just your basic htc keyboard with color change. ive tried multiple times to do and just cant seem to find anything that has to do with creating a skin for the keyboard. computer iliterate i guess.... if any has the time to possibly talk me through me via skype or yahoo please email me at mikeyboi83@gmail.com thanks a bunch
