New improvement in the latest beta: the skin is now cached in the internal phone storage once you select it, so you can now use the keyboard even when the SD card is unmounted, and performance should be increased a lot!
Waiting for your feedbacks ;)
cyril wrote:New improvement in the latest beta: the skin is now cached in the internal phone storage once you select it, so you can now use the keyboard even when the SD card is unmounted, and performance should be increased a lot!
Cyril, not sure what this means. Does this mean I should move my "Skins" folder to somewhere else? It's currently a folder in my phone's internal memory (not the microSD). I would like to take advantage of the increased performance (assuming it refers to less lag, etc).
Edit: I'm realizing this might be meant for skin developers... am I correct?
Works great so far. MUCH faster!
Thanks!
-Link
cyril wrote:... the skin is now cached in the internal phone storage once you select it, so you can now use the keyboard even when the SD card is unmounted, and performance should be increased a lot!
Everything looks fine so far; selecting a different skin goes smoothly, as well as loading and updating. I haven't noticed any significant performance increase when popping up the keyboard, although I suspect it's because I've been using a class 4 card all this time. For those of you who use a class 2 card, I'm sure this is a very nice feature to have.
I do love that it now stays accessible when the card is unmounted. :)
onthecouch wrote:Cyril, not sure what this means. Does this mean I should move my "Skins" folder to somewhere else? It's currently a folder in my phone's internal memory (not the microSD). I would like to take advantage of the increased performance (assuming it refers to less lag, etc).
No you don't need to move the "skins" directory anywhere. It means that the skins is copied automatically from (/sdcard/)skins directory to a private directory on phone storage, this is completely transparent. Of course if the "external storage" (usually it's associated to the /sdcard folder, but it may depend on the phone) is actually internal, I guess it will not make much difference. And for my information, where did you create your "skins" directory? Smart Keyboard should only be able to detect skins stored on the SD card...
@zen: I added the bold feature in the latest beta
You just need to change the label tag like this:
Code: Select all
<label bold="true">#FFFFFFFF</label>
By the way is it ok to integrate the Galaxy skin in the next version? (it's in the beta). I think many people would want it
cyril wrote:@zen: I added the bold feature in the latest beta
Code: Select all
That would be nice, it saves people from a few extra steps. I'll allow it :) Afterall, I'm a fan of SKPro ;)
I've updated the Galaxy with the new bold fonts tag, and also tweaked the Enter/return key symbol to look more like the original Galaxy S.
Download:
galaxy.zip
Galaxy, updated Oct 18
(25.7 KiB) Downloaded 917 times
Galaxy with bold letters
By the way,
The active state for shift symbol still needs fixing: :)
Code: Select all
<symbol><shift-locked>filename.png</shift-locked></symbol>
Any chance to fix it for the upcoming 3.7 release? Would be great if it loads that symbol, preferably on both states: shift toggled and shift locked.
Thanks Cyril.
Cyril, my "Skins" folder is in my phone SDcard. The internal one (aka not the one with Avatar movie).
onthecouch wrote:Cyril, my "Skins" folder is in my phone SDcard. The internal one (aka not the one with Avatar movie).
Ok, but I'm not sure I understand ;) On the Nexus one, there is only one SD card, and it's a microSD (inside the phone, of course), and it's accessible in "/sdcard" directory. When I say the skin is now copied automatically to the internal storage, I really mean internal ;) (i.e not the removable SD card, but the internal flash memory)
