eolsgaard
Phone: HTC Droid Indredible
Post by eolsgaard »
Out of curiosity, is there a way to alter the color of the preview pop-ups? On the default HTC skin, it's black, and on SKP it's white. It would be fun to experiment with lots of different colors!
onthecouch wrote:Thanks Cyril for clarifying. So Zen, are the orange/green versions hi-res also? : )
Yes :)
dsf
Post by dsf »
Hi, could someone please create like a version of the hd skins from better keyboard as i really like them, and i'm sure many others do too. thanks :)
sendvic
Phone: samsung i5700 galaxy spica
Post by sendvic »
Hi, good and easy way to create skins but i'd also like to change:
Is it possible?
dsf
Post by dsf »
Hi, will external skins slow down the keyboard, or make it less accurate please? Thanks :)
Per request i have modified my original GlossBlack skin to include blue button press and also added darkened mod, shift and alt keys. Hope you like.
Moved here: http://www.dexilog.com/smartkeyboard/fo ... f=13&t=622
Cyril,
Do you know if your keyboard will work on the Galaxy Tab? Any plan to support even higher res keyboards for that?
Well, afaik the maximum resolution supported by Android is hdpi (240 dpi). Is this tab supposed to have higher res? Bigger screen doesn't mean bigger res....
Correct, and it looks to be at 240 as well. So your keyboard will work with it?
So I guess yes, the keyboard is supposed to work on every single Android device running Android >= 1.5 (which means 99.9% of the devices)
