I read this thread with great interest. Your keyboard works really well but has a few glitches as described above.
I have a nexus one so if there are things that need trying, post here or pm me.
Bad predictions
Re: Bad predictions
I will also get my Nexus One soon hopefully (thank you Google
), so I will try to understand why and how its dictionary would be better
Re: Bad predictions
Found one before I lost my G1.
Enter "vsck". "backs" is suggested as default. "back" is the LAST word suggested. "back" should be the default, IMO.
And I still cannot find SKP in Market. Please help.
Re: Bad predictions
Was typing "servers" but no prediction found. Android Keyboard does with the same key combination. :\
Re: Bad predictions
I type "servers" and it works... can you try again? I think this would have something to do with the location where you press the keys, but I'm not sure yet where the problem could come from
Re: Bad predictions
OK.. just identified a subtle bug which explains that sometimes there are no predictions at all. It happens when you move your finger quickly over different keys.
Working on a fix...
Working on a fix...
Re: Bad predictions
Oh, it explains why it predicts sometimes and doesn't at others - for the same word! I'll wait for the update, sir.
Re: Bad predictions
I have to use Market Enabler to see the updates so notifications weren't automatic.
One more check: does typing "wont" or something similar default to "wont" or "won't"? I think "won't" be a better default!
Can we have "haha" as one of the words? Currently, I have to put it in user dictionary which I lose now and then because of constant formats.
Re: Bad predictions
For "won't", I need to change something in the autotext, and I plan to do it very soon.
For the lost dictionary, I plan to implement a backup system (standalone or thanks to MyBackup - the developers contacted me to integrate it)
