multi touch sometimes doesn't work
Re: multi touch sometimes doesn't work
I suspect that it is the same problem as the HTC Desire, and you need to restart your phone after installation right?
WillJitsu
- Phone: EVO 4G / Android 2.1
I don't recall if I had to restart or not right after the installation. I think I have about 8 keyboards installed so it's hard to remember the various issues with each one.cyril wrote:I suspect that it is the same problem as the HTC Desire, and you need to restart your phone after installation right?
nick.koutrelakos
- Phone: Motorola Droid 2.0.1
cyril, i just upgraded my Incredible to Froyo and the lag/shaky responsiveness has gone away.
frader
- Phone: Incredible 2.1
Is this likely to get fixed? I love everything about SKP but the lack of multitouch support on the incredible is super annoying. They figured it out on the stock HTC keyboard...
So the workaround (same as froyo keyboard) is here, in v2.8.0.
Now you can type "hahahahaha"
aamzalag
Hey Cyril,
I know that the last update was supposd to make a fix for multi touch, but after using it for the last 20 minutes, it has completely killed any semblance of multitouch that it used to have.. im not sure what happened
i cant type hahahaah any more, without my phone thinking i am doing a swype gesture and changing my keyboard. I loev the keyboard, and think it is the best. I hope that its not too big an issue.
Thanks man
adam
Thanks man
adam
I tested a long time before releasing this version, but maybe there are still problems on some phones
Which phone / ROM do you have ?
By the way if you have a HTC Desire or similar phone, it may be the standard HTC issue (you need to reboot your phone). I hope it's the case...
aamzalag
I have a moto Droid with 2.2 cyanogen 6 rom. The keybaord is not responsive at all anymore
