Skins! Request!<3 C:
yakie996
Phone: htc widfire 2.3.4
Re: Skins! Request!<3 C:
Post by yakie996 »
meyergre wrote:then just remove the 2nd extension on each of your files, once you unchecked the box, you should be able to see them. all your files finishes with ".png.png" instead of ".png".
After that, if it's still black,then the problem should be somewhere else...
always black --'
post your file
yakie996
Post by yakie996 »
plss
yarni theme.zip
(15.38 KiB) Downloaded 926 times
you forgot the following files :
just compare these filenames with the ones in your skin.xml, you will find all the mistakes ;)
yakie996
Post by yakie996 »
meyergre wrote:you forgot the following files :
witch mistakes i don't find..
the double extension, of course !
you only fixed the .9.png files, you should do the same for the other files.
in your skin.xml, you indicate to use backspace.png, but this file is actually named backspace.png.png in your drawable folder.
So, the names doesn't match, it can't work! ;)
EDIT : here is your skin, which should work now.
yarni-ok.zip
(15.24 KiB) Downloaded 1050 times
yakie996
Post by yakie996 »
meyergre wrote:the double extension, of course !
The attachment yarni-ok.zip is no longer available
notting works..
yarni theme.zip
(10.56 KiB) Downloaded 881 times
Only the button backgrounds are .9.png, other ones are classic .png !
If you naame them .9.png, the skin engine will search for the black lines, specific from the .9.png file format. Use this format only for stretchable pictures !
To sum up :
Name your symbols only ".png", and do the same in the skin.xml.
Don't touch the buttons anymore, if should work.
Post by shirley0123 »
Cheap Asics New Style Lovers utilizes pad the forefoot along employing the heel, as well as they entirely fulfill by by themselves to precise varieties of ft and gait. The enterprise for Running shoes is precise mostly since the Asics Gel Stratus 2.1 Shoes approaches fulfill the wishes for of separate people with entirely divergent leg profiles and Running styles.
