Haloruler64 wrote:I know, the .9 was a stupid mistake :/ thanks though!
I tried to fix the xml, but it still doesn't work. Attached.
Here it is, working ;)
3D.zip
(64.47 KiB) Downloaded 731 times
I wrote the modification I told you in the XML, compressed once more, sent to my tablet, and... ta-daaaa! :)
Well, it's 11:22 PM on my side, so I'll go to sleep now :geek: have fun!
Haloruler64
Phone: Samsung Galaxy S, Android 2.3.4
Post by Haloruler64 »
Thank you SO much! It's highly appreciated! :D
What did I do wrong in my xml? I can't tell.
i'm not an expert, but i guess the <color> tag you used is not supported. in the xml i gave back to you, i'm using a gradient -as you did in your background- with the same color for the top and the bottom. you can use a .9.png picture too, but don't forget the expand marks on it ;)
Haloruler64
Thanks so much man :)
Last question: Do you know anything about spacing? Like, each lines indent? I noticed yours has 2 spaces more with each line. Is that standard?
meaning the gap between the keys ? there is no "standard" actually, i found a balance which seems pleasant to me, that's all :)
i've drawn themes with thinner gap, and others even without buttons :) so just do as it looks good to you ;)
note : think about low-res devices : if the gap is too big, the buttons will be too much thin, and the result could be ugly.
by the way, Cyril, is there a way to include ldpi pictures in the zip, like we can already do for hdpi with the drawable-hdpi folder ? i know the android sdk support it, but it seemed not to work in smart keyboard last time i gave a try.
Haloruler64
No, I mean the gaps, or indents, before lines in the XML. You have to spaces more for each line down. That the standard? Or can you just press tab?
oh, sorry. it's a easier to read with tabulations, like in every markup, scripting or programming language,but you're not forced to follow it. any software would read it, with or without them.
Haloruler64
Thanks a lot man!
You know, it'd be interesting to create a skin optimized for 3D displays... once more phones then just the EVO 3D/Optimus 3D have them.
flagirl
Post by flagirl »
Can these skins be built on your computer and loaded into the emulator via the desktop?? Everytime I try to load to the emulator it is telling me no projects are found. I would really appreciate any help..
