robbiep
Phone: cdma hero, cm6 nightly #99
Post by robbiep »
Link wrote:robbiep,
Thanks for the compliments and sorry for the trouble. I have modified them again. Try again and thanks for testing. ;)
Anytime. I love clean and simple themes. And I have plenty of time to test stuff out on the weekends.
Anyway, still no luck though on this newest GlossBlack.
robbiep wrote:
Link wrote:robbiep,
Ok, I have checked and double checked, resaved everything and made a new ZIP file. Please try again and if this doesn't work I would appreciate it if someone could take a look at my files and help me find what is wrong.
mikeyboi83
Phone: htc evo android 2.2
Post by mikeyboi83 »
i was wondering if anyone could possibly have the time to help me make my open skin something simple and easy hopefully just your basic htc keyboard with color change. ive tried multiple times to do and just cant seem to find anything that has to do with creating a skin for the keyboard. computer iliterate i guess.... if any has the time to possibly talk me through me via skype or yahoo please email me at mikeyboi83@gmail.com thanks a bunch
robbiep
Post by robbiep »
Okay. So, I hate to be the bearer of bad news, but it still doesn't like my mdpi resolution. Still plain black skin. I wish I was a dev who could look into it and help. The most I can do is try it and report back.
The 3DKey one is good though. Not sure if that fix is related at all.
dsf
Post by dsf »
robbiep wrote:Okay. So, I hate to be the bearer of bad news, but it still doesn't like my mdpi resolution. Still plain black skin. I wish I was a dev who could look into it and help. The most I can do is try it and report back.
Could you maybe take a video of the problems, and upload it to you tube, so it would be easier. This is properly a stupid idea though :)
That won't be necessary... There was indeed a problem in GlossyBlack skin, the file "mod.9.png" was called "mod.9 .png"!
Here is a fixed version
Link, by the way, can you create separate topic for your skins as Zen did? Thanks
glossy.zip
(39 KiB) Downloaded 811 times
robbiep
Post by robbiep »
Yes! Works great now. Thank you both. I love the android community.
PROXIMO
Phone: Wildfire
Post by PROXIMO »
Please make some nice skins for QVGA with 64k colours !
Actually QVGA is not supported at the moment (well, it is, but the images are scaled), I need to add this in a next version
cyril wrote:That won't be necessary... There was indeed a problem in GlossyBlack skin, the file "mod.9.png" was called "mod.9 .png"!
Thanks and here are the new topics:
3DKey: http://www.dexilog.com/smartkeyboard/fo ... f=13&t=623
GlossBlack: http://www.dexilog.com/smartkeyboard/fo ... f=13&t=622
