Text issue with Copilot
sinan
Phone: HTC Wildfire Android 2.2
Re: Text issue with Copilot
Post by sinan »
cyril wrote:"com.android.vending" is the name of the Market app, not Copilot. Can you try again just (I mean a few seconds) after typing something in Copilot?
aha! OK, here it is:
03-01 21:09:02.182 D/SmartKeyboard( 172): Called from package com.alk.copilot
So it's the correct package name, it should work... Is it with QWERTY or T9? Have you changed specific text prediction settings?
sinan
Post by sinan »
cyril wrote:So it's the correct package name, it should work... Is it with QWERTY or T9? Have you changed specific text prediction settings?
it's the keypad without T9. isn't it supposed to work also with the text prediction? i have the "always suggest" off, that's all.
by the way, it never worked with copilot after I got the android 2.2. it was OK when I had android 2.1 with the previous version of the copilot. this problem occurred only with the current copilot.
