Here is another that I tried to model after a laptop. What do you guys think? I am not to happy witht he colors yet. ALSO, anyone know why the characters and the special characters are so close together?
dsf
Post by dsf »
Link wrote:Here is another that I tried to model after a laptop. What do you guys think? I am not to happy witht he colors yet. ALSO, anyone know why the characters and the special characters are so close together?
Hi, I think this looks cool, but the blue needs changing a bit I think, as I find it a bit too over powering and it doesn't look right :) , but other than that I think it looks really cool :)
also
I have noticed an intermittent lag difference between the external and internal skins :)
Another version a little more glossy and removed the shift light.
sublow
Phone: x10 Mini
Post by sublow »
Would any of you guys be able to konck up a skin that has the same colour scheme is this?
It would look great on the x10 mini range as the rest of the phone is blue like the keyboard.
I would like the same layout of the HTC skin but a blue colour scheme.
:D
Dolph
Phone: Milestone Russian Android 2.1
Post by Dolph »
zen, thanks for the droid keyboard, cool thing. But I'm splitting between galaxy and droid skins for now :D. The smartphone is moto milestone (droid for USA market).
inate71
Phone: Motorola Droid (Stock 2.1)
Post by inate71 »
Could someone make a keyboard themed like that? Please??? :)
MeDo159
Phone: HTC Hero
Post by MeDo159 »
Hi guys, Thanks a lot for sharing the good work!
I have a strange problem, I did exactly what was mentioned,
I created skins folder in SDcard and copied the skins inside it (just the zip files without extracting them), the skins appeared and I can choose any of them, but all I see then is just black background!
see the attached screenshot, this is the result for any skin I add other than built in skins :(
Note: I use Hero (Floyo 1.01 Rom), which is Froyo :)
MeDo159 wrote:Hi guys, Thanks a lot for sharing the good work!
Not sure if I understand fully but all files need to be in the same structure as the other ones posted here into a single ZIP file named the same as the name in the xml file. Also make sure the png files have been created with the correct batch9 layers included. I have had issues in the past if there are any artifacts in the batch9 layer. If you want, post your skin here and we can take a look.
-Link
MeDo159
Phone: HTC Hero
Post by MeDo159 »
-Link
Sorry I guess I didn't make my self clear :oops:
I'm not designing a skin, I'm using a ready one!
I downloaded few skins from users posts here in this thread and tried to use them, where I faced the problem I mentioned above.
A black skin means there was an error while reading the skin. Which .zip have you installed? Is it with the latest version of SKP?
