Text issue with Copilot
Re: Text issue with Copilot
This is a known issue (http://bugs.smartkeyboardpro.com/view.php?id=40)
I tried once to reproduce but didn't have this problem (though I canceled my order before the 24h deadline, so maybe the problem only happens in the full version?). Can you tell me if it happens everywhere in this app or in specific fields?
As it happens only in Copilot, I would say this is a bug in this application, as it doesn't use the standard android widgets for text edition. Can you test with quick fixes / suggestion etc. disabled? I suspect they don't handle this correctly, so if I'm correct, a workaround would be to disable it automatically when using Copilot
ryznar
Phone: Motorola Milestone - Android 2.1
Post by ryznar »
Thanks for the quick reply cyril.
Yes it happens in all text fields.
I unticked only quick fixes (which unticks/disables various other settings) and this fixed the problem.
How do I automatically disable quick fixes when using copilot?
That's the whole problem ;) I need to find a way to detect that the keyboard is used inside Copilot, I don't know if it's easy
ryznar
Post by ryznar »
Ok, thanks for that, let me know if/when you succeed!
gubbero
Post by gubbero »
I'm also experiencing this very annoying bug.
However I noticed one thing this morning. This only happens when you insert letters or signs accessable from the letter mode.
I dosen't happen for numbers or signs in the number mode.
Never experienced this problem with other keyboard apps so I don't think it's fair to blame it on Copilot.
// Suzpel
Well, from what I understand, the problem is that Copilot doesn't handle well "composing text" (text which appears as underlined when you are in a "normal" app). I guess you have this problem in Copilot because you enabled the option "Always suggest", which may not exist in other keyboards, which forces the keyboard to use composing text every time. So, try to disable this option, and I am pretty sure it will work better
So, that was the problem! (when I tried first to reproduce, I had "Always suggest" disabled...)
Now, "always suggest" is disabled automatically when the keyboard is used in CoPilot. This will be in the next update
ryznar
Post by ryznar »
Great stuff cyril, thanks for that, when can we expect the update?
5 min ago ;)
gubbero
Post by gubbero »
Thanks for the update !!!!
Great work
// Suzpel
