3DKey skin
chris6278
- Phone: nexus one 2.2.1
Re: 3DKey skin
How do i move it into that folder?
Re: 3DKey skin
Either plug it into your computer or use an app like Astro File Manager.chris6278 wrote:How do i move it into that folder?
chris6278
Re: 3DKey skin
Im using astro an when i download it it goes into the download folder my ? is how do i move it to the skins folder?
Re: 3DKey skin
Just like windows, copy paste.
Tap-hold on file
Select move or cut
Change to skins folder
Paste
Tap-hold on file
Select move or cut
Paste
chris6278
Re: 3DKey skin
Thanx i got it to work. Can u please post a link to that blue one on the front page? That one looks pretty cool
studlyadam
- Phone: cdma htc hero froyo
Re: 3DKey skin
I agree with this person can you please post a link to the alternative version and could you do a version like that other guy said with a transparent background not the keys just the background that would own. Thank you!!chris6278 wrote:Thanx i got it to work. Can u please post a link to that blue one on the front page? That one looks pretty cool
stefanl
Re: 3DKey skin
I would also love a link to the alternative color
Re: 3DKey skin
Ok, I posted the ZIP on the 3DKeyBlue and here is the 3DKeyClear. Not sure this is what you want but take a look.
- 3DKeyClear.zip
- (52.38 KiB) Downloaded 2823 times
hotaru
- Phone: htc hero cdma / cm 6 (android 2.2.1)
Re: 3DKey skin
it looks like you only changed the hdpi images in 3DKeyBlue... any chance you could change the mdpi ones, too?Link wrote:Ok, I posted the ZIP on the 3DKeyBlue and here is the 3DKeyClear.
edit: file removed.
anyone may use and modify any smart keyboard skins that i post on this site.
you may distribute those skins or modified versions of them for free.
you may not sell any of my skins or any derivative works of my skins.
Re: 3DKey skin
I have updated the original post attachment. Please remove this version so we don't get confused.hotaru wrote:it looks like you only changed the hdpi images in 3DKeyBlue... any chance you could change the mdpi ones, too?Link wrote:Ok, I posted the ZIP on the 3DKeyBlue and here is the 3DKeyClear.
edit: i decided to try doing it myself... just resized the hdpi images and fixed up the border, then put them in the folder for the mdpi images.
I have also updated the CLEAR version to include mdpi as well.
