Skins will NOT show up for me. I have done the following:
1. Created /sdcard/skins folder.
2. Placed three skins in previous folder in ".zip" form.
3. Checked "general settings--->select skin" for skins and they are not there.
What am I doing wrong?
How to install skins
card-us
- Phone: SE X8 & OS ver. 1.6
Re: How to install skins
hai, i had problem with skins of smartkeyboard. last week when i used smartkeyboard trial the skins are show at list, but when i upgrade it to smartkeyboardPRO the list of my downloading skins are not appear on the list. (i already put skins folder on the Root of my SD card.
can someone help me for this problem
thanks before
thanks before
prog-amateur
Exactly the same problem. Please help us. I have the PRO version too.dubluv17 wrote:Skins will NOT show up for me. I have done the following:
card-us
Found it the problem, it just got solve after i used SKP ver 3.4.0 it detect the skins very well & it has the same interface as the trial version ( only the PRO doesn't had popup thing)prog-amateur wrote:Exactly the same problem. Please help us. I have the PRO version too.dubluv17 wrote:Skins will NOT show up for me. I have done the following:
KingstonBS
- Phone: Droid X Android 2.3
I cannot get any skins to show up? I have followed all the instructions, so frustrated!!!
Centerman
- Phone: Samsung Captivate SGH-i897
This is how I got the Keyboard skins to display on my Samsung Captivate.
1. Created /sdcard/skins folder...... This is where the problem was for me
The skins folder you make must be in the root directory of the phone itself. Not in the sdcard folder or on your SD chip.
Skins now display and work fine.
KingstonBS
I give up...it just doesn't work!
I'm using a droid X & I've tried all these & nothing works. It just shouldn't be this difficult.
Everyone keeps saying in the root of your phone or SD card, but everything I've tried won't let me access he root directory
nicky041192
- Phone: HTC Wildfire Official 2.2
do you know what what the root of your SD card means...?KingstonBS wrote:I give up...it just doesn't work!
Shorte85
- Phone: Droid Incredible
I'm having the same problem as well and was hoping someone could help me out.
I thought that the root of the SD card or phone is where all the folders and what not are. Am I incorrect? If so, please be elaborate in what needs to be done as I have been at this for the past 2 days. Thanks
The root of the SD card is the directory called /sdcard (or /mnt/sdcard) when you use a file explorer on your phone, but if you plug your phone to your computer via USB, the root of the SD card is just the root of the USB drive which appears on your computer.
